Spring is officially here. You can feel it in the light, in the air, in the quiet, persistent pull to step outside and stay there a little longer.
When spring arrives, it doesn't announce itself in a dramatic way, but in small, steady moments. A bit more color in nature. A bit more warmth on your face. The sound of birds returning in the early morning. Evenings that stretch just enough to make you pause before heading back inside. It’s really subtle, but it’s there.
There’s definitely a shift in rhythm. A gentle invitation to slow down, to look up, to move differently through your day.
Most of us notice it, however, fewer of us actually respond. Because even when we do finally step outside, into the spring air, we rarely leave everything behind.
For many of us, the same habits follow us. Notifications. Quick checks of the phone (maybe just to check the time, but then we’re pulled into the screen). There is a quiet urge to stay connected, even in moments that don’t ask for it.
So, in the end time still feels structured, measured in tasks, messages, and things waiting for our attention.
However, when we’re outside, connecting with nature, you don’t have to be tethered to technology.  There’s a different rhythm to be found. One that isn’t dictated by alerts or deadlines, but by the pace of your steps, the changing light, the distance between where you started and where you end up.
It’s slower. More grounded. More real.
And when you allow yourself to settle into it, even briefly, something shifts. Focus returns. The noise fades. What once felt urgent starts to lose its hold.
This is what it means to keep time with nature’s rhythm. So, the question becomes, will you answer the call?
What if the only thing you brought with you was time itself?
Answering that call doesn’t have to require a complete reset. It can start with something smaller. A conscious decision to leave a few things behind, and to carry only what truly matters.
Not more apps or wearable technology with more notifications. Not another device competing for your attention.
Just time.
Mudita Radiant Automatic Means Time, Without the Distraction
But not the kind of time that interrupts you, but the kind that moves quietly in the background. Steady. Reliable. Always there when you need it, and never asking for more than a glance.
This is where Mudita Radiant Automatic fits in. Not as something that demands your focus, but as something that supports it. It’s a field watch designed to do one thing well, to keep time, and to let everything else fall away.
Powered by a Swiss-made automatic movement, it doesn’t rely on batteries, updates, or constant interaction. It simply moves with you, powered by your day, not by a charger.
And in those moments when you do check the time, whether you are on a trail, by the water, or just stepping outside between tasks, it becomes a quiet gesture. Brief. Intentional.
And just as quickly, your attention returns to where it should be.
Swiss Precision, Field Tested
There’s a certain confidence that comes from knowing something simply works. There’s no second-guessing, no  need to check, recharge, or adjust anything. You just feel a quiet sense of reliability that stays with you, wherever the day leads.
Mudita Radiant Automatic is built with that kind of intention.
It’s hand-assembled in Switzerland and  powered by the Sellita SW200-1 Elaboré automatic movement, a mechanism known for its precision and durability. The  purpose isn’t to impress (even though it does), but to last. Mudita Radiant Automatic is a field watch built for uninterrupted endurance, day in and day out, with every step.
It’s the kind of craftsmanship you don’t have to think about, and that’s exactly the point.
Whether you’re moving through a forest trail, navigating uneven terrain, or simply going about your day outdoors, Mudita Radiant Automatic is a field watch designed to keep up without ever getting in the way.
Even as the light begins to fade, it remains easy to read. The custom-designed numerals and Super-LumiNova® BGW9, one of the brightest and most reliable luminescent materials available, ensure clarity at a glance, whether it’s early morning, late evening, or somewhere in between.
The luminous glow of time itself. Mudita Radiant’s Swiss Super-LumiNova® BGW9 shines with clarity, even in the darkest moments.
Everything about it is considered. Not to add more, but to ensure nothing is missing.
At Mudita, we believe that when you’re outside, fully present, the last thing you should have to think about is the tool on your wrist.
Inspired by Nature’s Palette
When Spring makes its return, it’s the colors that you see first. Perhaps, not all at once, but gradually. Greens that feel deeper than before. Earth tones that carry warmth. Blues that stretch a little further across the sky.
The colors of spring are very revealing, but never overwhelming.
Mudita Radiant Automatic draws from that same quiet transformation. Moss Green, Sand Beige, Baltic Blue. Colors shaped by the landscapes you move through, not by trends or distractions.
They don’t demand attention, but subtly settle into their surroundings.
On the trail, they feel natural. By the water, they feel at home. Even in the stillness of a quiet morning, they reflect the calm of the moment rather than interrupt it.
It’s a different kind of design approach, one that doesn’t try to stand out, but rather to belong.
Because, we can all admit that when you’re fully present, the last thing you need is something competing for your attention.
The Perfect Fit for Every Story
I think we can all admit that the moments that shape our days are as unique and varied as the days themselves.
Some days are a whirlwind, spent moving, exploring new places, following trails that don’t appear on a map. Others feel a little quieter. A slow morning. A familiar path. A pause between everything else.
Mudita Radiant Automatic is designed to move with all of it.
With sizes ranging from 32mm to 40mm, it offers a fit that feels natural from the moment you put it on. Not too heavy. Not distracting. Just present, in a way that feels effortless and right.
At Mudita, we understand that comfort isn’t only about how something sits on your wrist, but how easily it becomes part of your day.
Whether you’re out in nature or simply stepping away from the noise for a while, Mudita Radiant Automatic adapts without asking anything in return.
It doesn’t define the moment. It stays with you through it.
Discover Mudita Radiant Automatic, a Swiss automatic field watch combining precision, durability, and minimalist design. Now live on Kickstarter.
As part of this spring campaign, there’s also something extra waiting for you.
When you add Mudita Radiant Automatic to your cart, you’ll be able to choose a complimentary second strap before checkout. It’s our way of giving you a bit more flexibility for the season ahead, at no additional cost.
Build a more thoughtful relationship with technology in 2026. Learn how mindful tech use & mindful devices can help you reclaim focus, rest, and balance.
