It’s 11:30 PM. You’re exhausted, but you’re lying in bed, staring at the ceiling, wondering why sleep won’t just come.
Here’s something many people don’t often realize: by the time your head hits the pillow, the quality of your sleep has already been decided. It was shaped by your morning, your lunch break, the hour before bed. The pillow is just where you find out the result.
And while that might sound frustrating, it’s also strangely freeing.
That’s because it means better sleep isn’t really about what you do at 11 PM, or whether you feel tired enough. It’s shaped by small, human decisions scattered throughout the day.
None of them are dramatic, however, all of them are doable.
Let’s take a look at what putting sleep first actually looks like in real life.
Morning: How you wake up matters more than you think
Although we might not like to admit this, the first moments after waking often set the tone for everything that follows. Reaching for your phone the moment your eyes are open, immediately pulls your attention outward. Messages, updates, notifications. Before your mind has fully settled into the day, it’s already reacting.
Putting sleep first can begin with something simpler.
It means a slower start. A bit of light. A few quiet minutes before engaging with the world. We understand that this may be much harder to accomplish when you use your smartphone as an alarm clock. You have to reach for it, just to turn off the alarm, so, you’re already making contact with the device that intends to pull you in. However, making a small change, like switching to a traditional alarm clock, like Mudita Bell or Mudita Harmony eliminates the presence of the smartphone on your nightstand. Thus, allowing you to experience a more mindful morning.
Start your say more mindfully with Mudita Harmony 2
Start your day more mindfully with Mudita Harmony 2
READ: Mindful Mornings: The benefits of an offline morning routine
Additional small shifts, like opening a window, stretching, or sitting in silence for a moment, help regulate your internal rhythm. They signal to your body that the day has begun in a steady, grounded way.
And that steadiness carries forward into the evening.
Midday: Working with your energy, not against it
There’s a point in the day when energy dips. For many people, it’s ignored.
Some grab another coffee (or an energy drink). Some push through fatigue. Some attempt to override what the body is clearly signaling.
However, putting sleep first means noticing these moments and responding differently.
Stepping outside for a short walk. Eating a proper meal & staying properly hydrated. Giving your mind a brief pause instead of constant input.
These are quiet corrections, not dramatic changes.
What they do is reduce the buildup of stress that often shows up later as restlessness at night. READ: Ten Simple Habits to Change Your Life
Evening: Creating space instead of stopping abruptly
One of the most common patterns is moving at full speed until the very last moment.
Yes, work ends, but your smartphone stays in your hand. This means your mind is still active, processing, reacting, absorbing.
Then suddenly, it’s time to sleep. The body doesn’t work that way.
A simpler way to think about this is that sleep isn’t a switch, but more like a transition. Your mind and body need to prepare. It’s actually a biological process. READ: What Happens When You Sleep?
Putting sleep first means allowing that transition to happen gradually.
Lowering the lights. Letting conversations slow down. Stepping away from content that keeps your mind alert or emotionally engaged.
It’s less about a single, specific action, and more about creating an environment where nothing is pulling your attention in ten different directions. READ: How to Create an OFFLINE Bedtime Routine
Before bed: Letting your mind settle
The habit of “just one more scroll” is rarely just one. It, very often, can last for a LONG time.
Endless content, notifications, and updates keep the mind in a state of low-level alertness. Even when you feel tired, your brain is still engaged.
This is where a small boundary, like leaving your smartphone in another room,  can make a meaningful difference.
Reading a few pages (of a book, NOT on a screen). Sitting quietly. Letting the day settle without additional input.
This shouldn’t be a rigid routine, but more like a signal that the day is coming to a close. READ: What happens when you use your phone in bed?
The role of your environment
Sometimes, the biggest shift comes from what you remove. When the bedroom becomes a place associated only with rest, the body responds differently. There’s less tension, less anticipation, less mental noise.
This is why many people find it helpful to move away from using their phone as an alarm.
A dedicated device, like Mudita Bell or Mudita Harmony, creates a clear boundary. No notifications. No late-night scrolling. No sudden pull back into the digital world.
Start your day without the pull of a smartphone screen with Mudita Bell 2 or Mudita Harmony 2
Just a gentle start and end to the day.
It’s a small change, but it reshapes the entire rhythm around sleep.
READ: Digital Detox Resolutions: Break the Screen Cycle & Sleep Better
Sleep is not something you squeeze in
For a long time, sleep has been treated as flexible. Something to adjust, delay, or sacrifice when needed. And let’s be honest, hustle culture hasn’t helped with putting sleep first. READ: Why Hustle Culture Is Ruining Your Sleep (And Your Productivity)
At first, effects are rarely immediate. They show up slowly. Less focus. More irritability. A constant sense of being slightly off, not all there.
Putting sleep first means recognizing that rest isn’t separate from the rest of your life. It supports everything else.
And often, it doesn’t require a complete overhaul.
It starts with small decisions:
  • A quieter morning
  • A more intentional pause during the day
  • A gentler transition into the evening
You see, none of these are dramatic changes, however, together, they change how the body and mind arrive at night.
A different question to end with
Instead of asking how to “optimize” sleep, it may be more helpful to ask something simpler:
What did my day feel like, and how might that shape the way I rest tonight?
Because in the end, sleep is not something you force.
It’s something you allow.
